TwinTurbo.NET: Nissan 300ZX forum - A properly installed timing belt can appear to be off
Subject A properly installed timing belt can appear to be off
Posted by canyoncarver on November 10, 2009 at 6:51 AM
  This message has been viewed 164 times.
In Reply To Re: Re: How do you set the crank balancer pulley to "0"? posted by ZTurboFan on November 10, 2009 at 12:28 AM
Message close to two teeth to the reference marks on the backing plates. The o.p. doesn't know if his belt is installed correctly. I was providing a way to check without complete dis-assembly. If the marks on any of the 4 cams are out more than the range noted, he definitely has to take it back apart.
